My RV-8 build
Date:  9-8-2011
Number of Hours:  1.50
Manual Reference:  Page 7-5
Brief Description:  Left wing fuel tank part #4
After completing the drilling of the outboard Z bracket for the left wing, I removed the clecoes from baffle/skin and removed the skin and attached ribs. I then moved along and drilled the remainder of the baffle/Z bracket holes.
I'm very happy with the results.
Onto deburring the componets of the left wing fuel tank and onto the capacitive system. I will also be adding the Hotel Whisky bung kit on the outboard rib for the ER tanks.
Left wing fuel tank skin and ribs removed
Z brackets drilled and clecoed
Not a bad technique!  Van's should put this in the plans!
